engine problems, need help
Old Jul 18, 2009 | 02:28 PM
dmyers's Avatar
dmyers
Default engine problems, need help
hey guys, my 02 v6 mustang (manual transmission) is having a problem that the local shop cant figure out. i was leaving work last sunday and while i was shifting from first to second gear my rpm's rose to 2500 and stuck there while the clutch was in. it did the same thing from second to third. at stop it idled at 1100 rpm which is obviously high. the local shop replaced the throttle position sensor and it helped none. any ideas what might be going on with it?
Old Jul 18, 2009 | 06:24 PM
l_shizzle_l's Avatar
l_shizzle_l
Was your AC on at the time? My rpms used climb to 1k-1.2k when running my AC but then the AC went out all together. Try cleaning your Idle Air Control(IAC) that could help as well.
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
HIS S-197
Aug 10, 2015 05:47 PM
Pain.
Aug 7, 2015 10:48 PM
