Got the engine.. Oh so sweet
Well the engine got here.. Everything looks great and we have it out of the crate and hanging.. now my question is this.. i was talking with a guy at work and he is telling me that since i have it out and all that I can start putting mods on it before it even goes into the car.. like the headers and whatnot.. Is this true? What, if anything, can be put on before it even gets into the car? Also I will try and get pics up asap.
K-member? where would i find this and how much are we talking.. trying to build the bank back up... also I am going to assume that since you mentioned a k-member that it is something I should be installing correct? I mean is this something that needs to be done? I was just looking and found a couple for like 250 which isnt bad but also mentions having to upgrade the control arms and then if i upgrade the control arms i have to get c/c plates and coilovers.. i already purchased the Eibach lowering springs.. is there any k-members where you dont have to do all these upgrades or what?
This would be the best time to install a aftermarket K-member because your engine will already be out of the car. V6 K-member = GT K-member, they are both the same. Some K members are a direct bolt on and can work with the stock a-arms, not sure which those are though.
Dude get some pics of the engine before you drop it in, because it will never look this clean again.
For all this money you're putting into this car, you really don't sound like you know a lot of what you're buying/talking about.
What is your whole setup? I remember seeing you post a bunch of threads about buying a whole bunch of stuff, but I forgot what exactly it all was.
I recommend a QA1 K-member in mild steel with QA1 control arms and Maximum Motosports Coil-overs for the front.
The k-member is the the big metal thing that supports the engine, front suspension, and ties the front of the car in together, but it weighs a TON!
4.3L Forged SSM Block
Stage 2+ SSM Power Pak
BBK Cold Air Intake
VAP Intake Spacer
BBK 65mm Throttle Body which was matched to the intake
Mac LongTube Headers
Mac H-Pipe
ASP Underdrive Pulley
Ford Racing Aluminum Drivershaft
SVT Feul Pump
3.73 Gears
T-Lok
Roush Side Exhaust
SCT Programmer
Eibach springs, sway bars, shocks, struts
Nitrous Kit
Is it necessary to upgrade the K-member or just another mod to do??
