Scan codes
Old Aug 27, 2009 | 12:01 PM
jmahle67's Avatar
jmahle67
Default Scan codes
hey guys I just did a engine rebuild from blown head gaskets. I just got the car running, but it is rattling. I wanted to check the codes from the engine, i got 4. One is P0125, P0304, P0305 and P1000. I know that 304 and 305 are cylinder misfires. what could cause those? I did not have them before I blew head gaskets. Could my wiring on my fuel injectors be mixed up causign them to misfire? What other possibilities are there? and Can someone explain P0125?
Old Aug 27, 2009 | 12:38 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Did you put in new plugs?
Old Aug 27, 2009 | 01:17 PM
jmahle67's Avatar
jmahle67
no. i had just put in new plugs about 20k ago
Old Aug 27, 2009 | 01:20 PM
RyansQuick6
Reverse Gear Member
When you blow a head gasket it tends to ruin your plugs. Get a new set, I recommend NGK TR5's, about $14 a set.
Old Aug 27, 2009 | 02:34 PM
jmahle67's Avatar
jmahle67
wouldnt it have ruined all the plugs and not just one or two?? Also i cleared the codes and cylinder 4 came back but cylinder 5 did not. could it be a bad injector? I basically eliminated the wires in wrong spot based on how the wire was run.
Old Aug 27, 2009 | 02:38 PM
RyansQuick6
Reverse Gear Member
usually you don't blow all the cylinders when you blow a head gasket since once pressure is relieved through one cylinder, maybe only 1 other one fails.
I just replaced mine a while back because one cylinder had a pinhole in it and the spark plug was white.
Old Aug 27, 2009 | 07:39 PM
jmahle67's Avatar
jmahle67
dumb question but how do i know if a spark plug is bad?
4cylinderplus2
Oct 9, 2020 07:45 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
