Battery problem
Old Aug 29, 2009 | 12:18 AM
SmallBikeRider's Avatar
SmallBikeRider
Default Battery problem
2002 v6 mustang automatic
My car has drained 2 batterys in the past two days.
It just has a fast-paced clicking and wont even turn over.
Any sugestions would help a lot
Old Aug 29, 2009 | 05:45 AM
fearthisinc's Avatar
fearthisinc
any new installs? probably should check alt.
Old Aug 29, 2009 | 07:35 AM
Richbrad08's Avatar
Richbrad08
Make sure your terminals are clean, make sure it grounding. and check alternator.
Old Aug 29, 2009 | 12:34 PM
SmallBikeRider
There are no new installs at all.
Sometimes when you turn the key all of the gauges move all the way to the right then back to normal.
Other times the gauges dont move.
Each time before it did this the car wound start and run fine all day, but both times is after i park and go in somewhere for about 10min and come out there is a repetitive clicking but it wont turn over.
Old Aug 29, 2009 | 03:12 PM
JKs95stang's Avatar
JKs95stang
What he^ said it sounds like an alt issue, you can have it tested for free at your local parts store.
Old Aug 29, 2009 | 08:51 PM
Richbrad08's Avatar
Richbrad08
i had the same problem as you did with the gauges. do this take some jumper cables. Take the negative and put it on something metal like the alt bracket something that is to the frame. take the positive and put it on the positive terminal and see if it starts. if it does it is a grounding issue. i would buy all new cables and new terminals. if it dosent work then i would go to advance auto parts or auto zone and get the alt tested.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Art161
Sep 9, 2015 10:33 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
