obdII code help...p1633..
Old Sep 2, 2009 | 12:11 PM
killbillet's Avatar
killbillet
Default obdII code help...p1633..
so my check engine light came on so i got my scanner and ran the code
the code im getting is p1633
it said
aux inputs and aux outputs
i figured it was that the voltage got too low at one time and kicked the light so i erased it
it came back on, my volt guage is reading 12v in the on position and 14+ while running so im stummped
could it be my aux input where i have my radar detector connected,
ive just never ran across this code and the only thing i found on google what stuff i already looked into
thanks in advance for your help guys/gals
Kevin
Old Sep 2, 2009 | 05:46 PM
JKs95stang's Avatar
JKs95stang
Check your battery and alternator. Are you popping any fuses?
Old Sep 3, 2009 | 01:29 AM
killbillet's Avatar
killbillet
na no popping, everything seems to be fine, alt is putting out 14+ while running.....battery is showing 12 when idle, ive deleted the code several times and as soon as i start the car it comes back on,
im going to check my battery cables, and alt cables tom to see if any of them arent making a constant connection, i was driving down the highway when i came on
Old Sep 3, 2009 | 04:05 PM
JKs95stang's Avatar
JKs95stang
There has been issues I've heard of regarding the alternator wiring, worth a look.
Old Sep 3, 2009 | 10:45 PM
killbillet's Avatar
killbillet
I havent got a chance to look at it because ive been working a lot and its supposed to be raining this weekend so hopefully i can get it taken care of soon, thanks for the info
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
