HELP!! Car problems
Old Sep 12, 2009 | 08:58 PM
timborama2001's Avatar
timborama2001
Smile HELP!! Car problems
Hi I have just bought a used 1995 v6 stang from a dealer for $1500. An amazing deal. It does run it needs some work. But I need some mechanical help if possible. I test drove it but didn't notice that when I turn right & only when I turn right not left or straight line. The car hesitates or stumbles. If the turn is long enough or sharp enough it will cut out. It feels like it's not getting enough gas or something or even like the power cuts out. But it still has power. It starts right up and runs fine though after. It just had a fuel pump put in & fuel filter. I replaced the well needed air filter. I searched for it online and others have some problems with other makes & models with the same problem but to no answer for a fix. I don't get it. Also possibly due to this problem or something all together by itself. When in park I can rev the engine fine when in drive the engine revs but very low RPM's & will not get past 2000 rpm's in higher gears. Like its got a limiter or something is what it feels like. Just not the power it should have. Any help would be very appreciated. Thanks in advance.
djbigskrilla
Sep 20, 2022 01:04 AM
FD725
Aug 23, 2015 06:43 AM
jjwinel78
Aug 17, 2015 03:34 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
