Instrument Cluster issues
Old Sep 17, 2009 | 02:44 AM
turbofargo's Avatar
turbofargo
Default Instrument Cluster issues
My 2000 V6 instrament cluster has a weird problem. If you were to disect it vertically in the middle, the right side gauges and lights work fine, but the left side does not. So I know my temp, tach, and such but not how much fuel or how fast I am going, fun yes:-)
What should I look for as the reasons to this. It worked intermittedly for awhile, sometimes part of the day, now though it never springs to life. Loose wiring? Bad fuse? or what, and where would I look. Thank you:-)
Old Sep 17, 2009 | 08:24 AM
brent4's Avatar
brent4
Well if it isnt lighting up on one side the first thing I would check would be the bulbs....just my .02
Old Sep 17, 2009 | 08:37 AM
turbofargo's Avatar
turbofargo
Its not that the side won't light up, the whole left side won't work. Needles won't move, zilch. There was a day a few weeks ago where they came back on for a second, but that's it. That's why I think its a wiring issue but not sure. If I were to take the cluster out what would I have to look for/test to see?
Old Sep 17, 2009 | 08:51 AM
brent4's Avatar
brent4
Check the fuses
Old Sep 18, 2009 | 04:25 PM
turbofargo's Avatar
turbofargo
Do you happen to know where the fuses are for the instrument panel?
Old Sep 18, 2009 | 05:05 PM
brent4's Avatar
brent4
Sorry i dont know off of the top of my head and im not near my haynes manual to tell you..maybe somebody will chime in and help.
Old Sep 24, 2009 | 04:10 PM
Mirage's Avatar
Mirage
Fuses for my 2002 are located under the drivers dash, above the dead pedal, might be a black cover on them. Your owners manual has the fuse locations, (make sure its fusebox not power supply, two different boxes). You could try changing the fuses but most likley its a wiring problem. New gague clusters run about $250-300 so before buying one take out the old and see if there is an obvious problem.
Old Sep 24, 2009 | 04:12 PM
Mirage's Avatar
Mirage
Edit: doublepost, admins can delete.
Old Sep 24, 2009 | 08:56 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
It's not a fuse, it's something in the panel. Pop the cluster out and take a look at it. Cluster can fail, and you just may have had that very thing occur unfortunately.
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
