header flange bolt broken
Old Sep 24, 2009 | 10:49 PM
92lxsleeper's Avatar
92lxsleeper
Default header flange bolt broken
ok so when i pulled the head for the car, i need to take the stock headers off. i hook my impact up to the first bolt, and it breaks, same with the other side. now i have two bolts that i can't get to at all, but i know they are gonna break, so im gonna cut them from the top with my sawzall.
how hard is it gonna be to drill out the 2 studs on each header, so that i can just throw a galvanized bolt to hold the header to the downpipes?
or is there an easier way to take the stud off?
Old Sep 24, 2009 | 11:33 PM
brent4's Avatar
brent4
I dont know..just saying im about in the same boat but with the upper intake and the IAC..but good luck and hope you get it fixed.
Old Sep 25, 2009 | 11:18 AM
TheMichiganRA's Avatar
TheMichiganRA
WHY would you take an impact gun to something like that? The ONLY thing YOU should be taking a impact gun to is a lug nut.
Old Sep 25, 2009 | 11:21 AM
rfcsoulja's Avatar
rfcsoulja
Maybe not the ONLY thing, but header bolts shouldn't need an impact.Did you actually try and take off the nut or the stud itself?
Old Sep 25, 2009 | 01:29 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
I can;t believe you cut the broken studs off, you could have used vise grips to get them out. Just have the machine shop do it.
Old Sep 25, 2009 | 11:06 PM
92lxsleeper
i fixed them in 5 mins. i took the cutoff wheel to the studs, and drilled the bolt out.
Old Sep 26, 2009 | 02:16 AM
RyansQuick6
Reverse Gear Member
Did the threads come out ok?
Old Sep 26, 2009 | 09:13 AM
PNYXPRESS's Avatar
PNYXPRESS
Those bolts sould be pressed in like wheel studs, so you should be able to just knock them out.
Old Sep 26, 2009 | 11:43 AM
92lxsleeper
no i drlled the threads out. im just gonna run a regular galvanized 3/8" bolt with lock washers, to prevent them from ever getting rotted together again.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
junior04
Sep 28, 2015 10:53 AM
2poor4u2
Sep 26, 2015 11:08 AM
Sep 25, 2015 06:58 PM
