Car runs poorly and no check engine light
Old 09-29-2009, 09:56 AM
wolvrinewd
wolvrinewd's Avatar
Default Car runs poorly and no check engine light
I have a 2000 v6 mustang with 77k miles on it. Got some gas the other day and it ran poorly there after. I added some gas treatment and soon there after put some new gas from a different place in along with some fuel injector cleaner. I also changed the fuel filter. Still runs bad. Shakes badly at idle as well as under acceleration under 2k rpms. No check engine light has ever come on. I replace the spark plugs today and the problem persists. A friend said it could be vapor locking but does this still happen on new cars? Any thoughts on where to go from here....coil packs. spark plug wires???
Thanks in advance
wolvrinewd is offline
Old 09-29-2009, 11:23 AM
Richbrad08
Richbrad08's Avatar
have you check your lines?
Richbrad08 is offline
Old 09-29-2009, 12:05 PM
wolvrinewd
wolvrinewd's Avatar
By lines do you mean fuel lines? And if so, what should I be looking for?
Old 09-29-2009, 12:37 PM
RyansQuick6
Reverse Gear Member
RyansQuick6's Avatar
What do you mean by running poorly, what is the car doing?
RyansQuick6 is offline
Old 09-29-2009, 12:54 PM
wolvrinewd
wolvrinewd's Avatar
engine shakes badly at idle and when accelerating below 2k rpms it shakes and has loss of power. doesn't ever feel like its going to stall but seems to bog upon acceleration
Old 09-29-2009, 01:43 PM
RyansQuick6
Reverse Gear Member
Check your plugs, it sounds like you may have gotten some water in the gas.
Old 09-29-2009, 01:44 PM
wolvrinewd
wolvrinewd's Avatar
replaced the spark plugs this morning, no change
Old 09-29-2009, 03:11 PM
RyansQuick6
Reverse Gear Member
Get all the gas out of there, there may still be some bad stuff. Put in fresh fuel, take the fuel filter off and see if any solid particles come out. If so the new one may be clogged. You may have to drop the tank to make sure the sock didn't get blocked with debris.
It is also possible that it's just a coincidence, but your coil pack may be going out as well, or plug wires. How did the old plugs look? Post up a pic.
Old 09-29-2009, 03:12 PM
ramoyer1
ramoyer1's Avatar
i say coil pack or wires....
ramoyer1 is offline
Old 10-18-2009, 08:04 PM
wolvrinewd
wolvrinewd's Avatar
Its been a while of troubleshooting and I am still stumped. Ive got all the gas out, checked the fuel filter again and its not clogged. Talked to someone at Ford briefly and he said it shouldn't be ignition related or bad gas because it would then run poorly throughout all the rpms and not just below 2k. He said to look for a vacuum leak and clean the EGR valve. Can't find a vacuum leak and I cleaned the EGR valve. Still no change.
I still notice a real strong gas smell from the back end of the car that wasn't there before this all began. I there anything I am missing, since it ran bad after putting gas in it could it still be related to the fuel system?
Quick Reply: Car runs poorly and no check engine light
