Misfire
Old Oct 4, 2009 | 01:40 PM
Tac.css's Avatar
Tac.css
Question Misfire
Hello,
got a small problem here.. hopefully small, I own a 2000 Ford Mustang, 3.8L v6, recently it started to misfire in the 3rd cylinder, any possible ideas on what could be causing it to do that?
Thanks in advance.
Old Oct 4, 2009 | 02:06 PM
PNYXPRESS's Avatar
PNYXPRESS
Check your plug wires first. If no wires off, replace plugs and wires. If that dont fix it, then replace coil pack.
Old Oct 4, 2009 | 02:16 PM
Tac.css's Avatar
Tac.css
Alright, I also want to mention that the problem is intermittent, it will happen sometimes, but then it would go away. Would that mean that maybe its an electrical problem?
Old Oct 4, 2009 | 02:17 PM
Bartro's Avatar
Bartro
I had a problem with a steady miss. It ended up being one of the rear injectors was plugged. Cleaned it and it ran great......other than the problem I have now which I just posted in this forum.
Old Oct 4, 2009 | 02:46 PM
PNYXPRESS's Avatar
PNYXPRESS
Sounds like its either a loose plug wire or the coil pack going bad.
Old Oct 4, 2009 | 04:00 PM
brent4's Avatar
brent4
x2 to checking your plugs, wires, and coil packs.
Old Oct 6, 2009 | 05:37 PM
neo8222's Avatar
neo8222
i had a problem when under high load it would miss on many/random cylinders.. turns out my spark plugs had way overheated to the point of slight melting and the miss was from the spark jumping the plug wire to the block. so check and see if there are black marks on the porcelain of the plugs
Old Oct 7, 2009 | 12:39 AM
wmrcer's Avatar
wmrcer
First spark plugs,wires, coil pack..
if still misses do a compression check. If compression is good
then replace spark plug for cylinder that's missing
just had to do all this about a month ago so have first hand experince... pm if you need any help.
Urambo Tauro
Jun 10, 2016 03:28 AM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
bconboy
Sep 21, 2015 12:52 PM
chrisc
Feb 10, 2006 10:16 PM
ghoste
Sep 7, 2005 11:42 AM
