Misc. Engine Block Questions
Old Oct 6, 2009 | 05:44 PM
Mirage's Avatar
Mirage
Default Misc. Engine Block Questions
I'm thinking about painting my engine to protect it from rust and corrosion and to restore its origional shine. I have some questions about what the engine block is made of and how to paint it. Before I dive into it though, I want to get the opinions of the veteran mustang modders here .
Here goes then...
What is the engine block made of? It looks like cast aluminum?
How should i clean it off before i paint it? I already used 160 grit to clean rust and corrosion off. I realy dont want to use a hose on it. I know someone who did that and had $800 of repairs due to water damage, not worth it...
Can someone tell me what this thing is ontop of the engine. I know its a dumb question but its my first RWD and this part is usuialy covered. It has several curved pipes leading down from the air intake/throttle body. Does this thing seperate the air into the cylinders? Poor photo, but it was dark out.
How hot does the engine block get max, ~500F? I was thinking of Duplicolor High Heat paint (Silver) instead of their engine enamel.
The big question then... How difficult is it to paint an engine block in car. I'll probably spray paint the big stuff and use a paintbrush the details.
Old Oct 6, 2009 | 05:52 PM
Shaunmac9128's Avatar
Shaunmac9128
I think painting the actual block while its in the car would be tough without overspray. That is the upper intake manifold your looking at. It does distribute the air to the lower intake then heads then the actual cylinders. You could take off the upper intake and it would be much easier to paint.
Old Oct 6, 2009 | 10:46 PM
LilRoush's Avatar
LilRoush
Clean the block with anything from a wire wheel to a degreaser.
Normal high temp paint works just fine for adding some color.
Someone did that much damage using a hose? What did they do, run it in the air intake to try and clean the inside!?!? I hose mine off all the time.
I painted my block (out of the car) after a quick once over with a wire wheel, a good grease cutting soap and some time to air dry.
The upper intake will take very well to a good polish job. I like the look over a painted version - but that's just me.
Old Oct 7, 2009 | 12:52 AM
stangant's Avatar
stangant
by the looks of your question plz do not break the engine down. clean it with some degreaser and if you want you can pressure wash the engine, just cover the alt and coil pack.
Old Oct 7, 2009 | 06:39 AM
Mirage's Avatar
Mirage
I like that polish job LilRoush, what did you use to polish it with? standard car polish?
Old Oct 7, 2009 | 08:09 AM
Shaunmac9128
I think its a little more indepth than that.
Old Oct 7, 2009 | 01:36 PM
l_shizzle_l's Avatar
l_shizzle_l
I think I breathed in the paint a little....
Old Oct 7, 2009 | 10:11 PM
Azrael's Avatar
Azrael
....wow. I have to agree with stangant here, don't try to do anything too serious. Polishing your engine components like LilRoush did takes more than just some car polish. You have too grind the metal and smooth it out/shine it up. It is a bit of work, and not something you want to try on your own.
Old Oct 7, 2009 | 10:21 PM
Shaunmac9128
Yeah if you think its done with car polish you have alot more research to do.
Old Oct 8, 2009 | 01:05 AM
LilRoush's Avatar
LilRoush
All mine is was a few hours with a wire wheel drill bit and some elbow grease. Intake, alt, pulley brackets, heads, and even the exhaust manifolds......
You could get the upper intake to look like that without removing it.
