split port swap
Old Oct 21, 2009 | 10:10 AM
my94pony's Avatar
my94pony
Default split port swap
anyone who has done this could you please pm me i have a few detailed questions
Old Oct 22, 2009 | 04:22 AM
NeoTokyo's Avatar
NeoTokyo
No need to PM, by far the easiest thing for you to do is find a low mile 99-04 (if 01-04 then you need to buy a 99-00 lower intake manifold) and put that in, sell your old engine.
You will also need a return style fuel rail, an early model windstar fuel rail will work, you can also try a 97-98 F150 fuel rail.
Call up VMP for your tune or take it to your local tuner and your on your way.
Good luck.
-Eric-
PS. the 2001 is said the be the strongest block, its cost for the bare block new relfects that idea though I do not know the details as to why it is stronger and how it is different.
Old Oct 22, 2009 | 04:25 AM
NeoTokyo's Avatar
NeoTokyo
Ahh, I just saw that you have a 94', that is an OBDI system, may as well pick up a wrecked 99-04 and swap everything plus the brakes out. That way you can also upgrade to Cobra or Mach 1 brakes without needing to buy the booster and prop valve.
A wrecked 99-04 can be had for anywhere from $800-2000 depending on miles, options and damage.
You can make your money back by selling off the parts that you do not need.
-Eric-
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Bokeo
Oct 10, 2015 08:28 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
