Engine Oil Addative
Old Nov 10, 2009 | 12:56 PM
unit91's Avatar
unit91
Question Engine Oil Addative
Saw an internet advertisement about some type of engine oil addative that's supposed to reduce burning oil from worn rings. Supposedly you drain your oil, put in straight 40W oil, then add this stuff. It supposedly creates a barrier at the rings that keeps oil from passing by them and being burned. Anything to this, or just another scam?
Old Nov 10, 2009 | 12:58 PM
neo8222's Avatar
neo8222
sounds like a scam
Old Nov 10, 2009 | 01:06 PM
Shaunmac9128's Avatar
Shaunmac9128
agreed
Old Nov 10, 2009 | 02:27 PM
RogerDodger1's Avatar
RogerDodger1
Scam.
Using a thicker oil will always reduce oil burning, but will also increase engine wear, reduce fuel economy, increase emissions and reduce power.
Use a good synthetic oil in the correct viscosity and oil burning will be reduced.
Old Nov 10, 2009 | 02:47 PM
Derf00's Avatar
Derf00
Gentleman's Relish
If you're talking about this stuff
http://www.restoreusa.com/Engine_Res...FSReagodZkydqA
It's a stop gap measure IMO. Basically takes graphite like particles and uses the 40w oil as a carrier. As the engine heats up, the blow by gap gets filled with this stuff which somewhat bonds to the wall of the block thus reducing the gap betwen the rings and block.
Some people swear by it, others say it's snake oil. Never tried myself.
It's been around for decades unlike Slick 50 that came and went in less than 15 years.
Old Nov 10, 2009 | 03:41 PM
unit91's Avatar
unit91
OK. What's the deal with Marvel Mystery Oil? What's the mystery? What's it do VS what's it supposed to do?
Old Nov 11, 2009 | 11:42 AM
RogerDodger1
Pour in oil additives of ANY type are not a good idea as they upset the chemical balance of motor oil. There is no, "magic in a can". Forget pour in oil additives.
Old Nov 11, 2009 | 12:36 PM
neo8222's Avatar
neo8222
what about lucas thats some good stuff
Old Nov 11, 2009 | 08:51 PM
unit91's Avatar
unit91
What's LUCAS???
Old Nov 11, 2009 | 09:11 PM
fordforlife0225's Avatar
fordforlife0225
almost all of the lucas products are AMAZING especially their power steering fluid additive. it reduces noise soooo much its great. i have not used there trans additive or oil additive but i like sticking with regular oil. thats what engines are made for. id never consider using straight 40 in my engine NO WAY.
