Battery Light Flickers
Old Dec 18, 2009 | 10:26 AM
compdude97's Avatar
compdude97
rockauto.com, they have a bunch ranging from $100 - 260.
Old Dec 18, 2009 | 01:07 PM
sIx's Avatar
sIx
Yeah I do NOT recommend buying a re-man. from advance...
Old Dec 18, 2009 | 03:31 PM
champ7's Avatar
champ7
I see you work there do you get alot back how are there new manufacture ones.
Old Dec 18, 2009 | 07:41 PM
sIx's Avatar
sIx
IDK about all the other Advances, but I have a new one on my car and its working fine, but the Remans seem to come back WAYYY too often. Even though it says Lifetime warranty, unless the store manager is nice, after its been replaced once, you only have a 3 month period after that
Old Dec 18, 2009 | 09:05 PM
champ7's Avatar
champ7
Thanks six
Old Dec 19, 2009 | 01:57 AM
neo8222's Avatar
neo8222
there is also the possibility that the light it self is bad... well not the light but the "trigger" if you can even call it that. the light is determined on or off just by a resistor in the power line to the light.
Old Dec 19, 2009 | 07:54 AM
champ7's Avatar
champ7
Is There anyway to check the resistor do you know where t is located. thanks
Old Dec 19, 2009 | 03:01 PM
sIx's Avatar
sIx
Explain? from my small amount of experience that wouldn't make any difference unless it was actually causing a complete path for current.
Unless you mean the voltage regulator being bad? And to the OP, take the voltage regulator off the back and check the brushes. I had a similar problem before, but it seemed to only be at higher RPM. same with bad diodes
Old Dec 19, 2009 | 06:52 PM
champ7's Avatar
champ7
Is the voltage regulator built right into the alternator? Thanks
Old Dec 20, 2009 | 01:50 AM
sIx's Avatar
sIx
Did you say how many miles you have?
Attached Thumbnails Battery Light Flickers-alt.2.jpg   Battery Light Flickers-brushes.jpg
