Fuel Injector problems
I have a 94 Mustang 3.8- am not getting a signal to the #2 and #3 cyl. injectors. Have switched the injectors and they are good just not getting the signal to fire- hooked a noid light up and it does not flash. what short of the ECM could it be??? any help is appreciated.
I have access to a hand held scanner and it just shows "cylinder 2 misfire cylinder 3 misfire running lean "- I don't think it's dumping any fuel - 2 & 3 miss all through driving range- started with #2 then got worse and now 2 & 3 are missing.
You should check the injector harness to make sure it isnt cut, burnt or damaged in any way. Also check the connectors to make sure that the pins have not pulled away from the plug.
If you are looking for a 95' V6 wiring harness I have one, PM me if you want to buy it. I also have the ECM for the same car, its a 5spd car.
Also take a look at your fuel pressure, I think it is suppose to be 38.5psi, your manual will say exactly what it is.
Good luck.
-Eric-
Good luck.
-Eric-
zanemoseley
Sep 6, 2015 12:58 PM
