subframe connectors?
ok so I am not satisfied with the way my 2004 mach1 handles. Like crap if you ask me.
Are subframe connectors a good thing? I am not so sure because it does add weight.
Eventually I will install a new suspension at some point as well but from what I understand the subframe connectors increase rigidity which is a good thing.
Any opinions?
Any opinions?
Pretty sure the Mach 1 already has factory Subframe connectors but that isnt to say that you could put bigger ones on or a brace kit like Kenny Brown sells.
A Strut tower brace will really help a lot too, I think Steeda makes a Mach 1 specific brace.
You can also get a rear shock tower brace.
Tokico D-Spec shocks will also increase the handling of your car.
There is a lot more that you can do too from complete Grib in a Box from Maximum Motorsports to chassis stiffening.
Also, we have a Mach specific forum in here too.
https://mustangforums.com/forum/mach-1-section-86/
Also make sure to make a stop off over at Mach 1 Registry and register your Mach.
and yes I am already registered. Thanks!
jwog666
Dec 27, 2021 08:09 PM
Sep 16, 2015 07:53 PM
TfcCDR
Sep 14, 2015 12:08 PM
