udp
Old Apr 1, 2010 | 09:19 PM
josea's Avatar
josea
Default udp
udp's are really never talked about on this forum, and i was just wondering if they are worth the 230 that they are asking for them on v6mustangstuff.com
what are the pros and cons
thanks in advance
Old Apr 1, 2010 | 09:36 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
yup, get it, but call before you order and make sure it's in stock, everyone tends to sell out pretty quick. It took me a while to find one.
Old Apr 2, 2010 | 12:54 AM
robinson209's Avatar
robinson209
Yeah get a UDP. I got the one through RPM outlet and I recommend it.
Old Apr 2, 2010 | 09:10 AM
josea's Avatar
josea
ok guys and do you guys recomend the 42 % motoblue or the 25% asp and is this going to be a problem if i want to have at least a decent audio system, also is this going to affect my colling sstem in any way thank you
Old Apr 2, 2010 | 10:41 AM
robinson209
If you are going to get a HUGE stereo then I probably wouldn't get a UDP. If your audio setup is similar to the mach460 system or smaller then I can tell you'll that you will not have a problem (I didn't).
Old Apr 2, 2010 | 01:04 PM
sIx's Avatar
sIx
42%? have any charging issues?
Old Apr 2, 2010 | 03:33 PM
robinson209
No problems at all. My gas mileage has increased a bit too.
Old Apr 2, 2010 | 06:40 PM
RyansQuick6
Reverse Gear Member
My 42% makes the headlights VERY dim at the stoplights, but I have a big stereo and a ton of other stuff running, for a true DD car I'd go with a 25%.
Old Apr 2, 2010 | 10:34 PM
sIx's Avatar
sIx
Well, it is a True DD, but I just got rid of my sub/amp in favor of some LT's XD, almost never use AC unless its miserably hot AND raining, and she seems to stay at or over 1,500 RPM (unless at a stoplight). Still go with the 25% or do ya think I'd be able to get away with the 42?
Old Apr 2, 2010 | 11:55 PM
Shaunmac9128's Avatar
Shaunmac9128
I can't decide personally. But I've heard a good portion of the gain isn't actually from under-driving the accessories but from the lighter weight (udp) on the end of the crank which is why the difference in gains for the two is so minimal. Just hearsay.
2003DSGT
Dec 25, 2005 03:43 PM
jlauth
Dec 2, 2005 01:40 PM
Dan04COBRA
18
May 9, 2005 10:48 PM
The02GT
May 8, 2005 09:12 PM
