Lower?
Old May 17, 2010 | 04:14 PM
03blue6er's Avatar
03blue6er
would a 1.5" drop require new caster/camber plates etc.?
Old May 17, 2010 | 04:47 PM
brent4's Avatar
brent4
^ yes it will.
Old May 17, 2010 | 04:59 PM
moochman4life's Avatar
moochman4life
Just to be clear, the drop doesn't REQUIRE new caster/camber plates. However, because your front wheels will no longer be straight up and down - but more angled from inside to outside, top to bottom - you will see accelerated tire wear on the inside of your front tires...plus your car will pull a little more on uneven pavement.
Old May 17, 2010 | 05:22 PM
brent4's Avatar
brent4
^ and you fix that problem with caster/camber plates.
Old May 17, 2010 | 05:34 PM
moochman4life
The question was "require", fella. But you're absolutely right.
Old May 17, 2010 | 05:35 PM
crzydrumer14's Avatar
crzydrumer14
difenently a great mod. although relatively expensive (if done right) it makes a world of difference. Nomatter how much you lower it your handling will improve. and same with the looks of the car its gonna look better nomatter what. but i would just wait until you are able to get a good all round setup including caster camber plates. its worth it.
last year i installed the eibach prokit, steeda camber casterplates, strut tower brace, and rear sway bar. World of diference. and after you do that look into some 18'' rims with some nice tires.
Check out my sig for a pic with all that stuff installed
Old May 17, 2010 | 06:42 PM
LilRoush's Avatar
LilRoush
1.5" is border line needing the CC plates.
If you want to be safer, Roush makes a set of springs made to work with the stock V6 suspension parts. I have yet to hear of anyone not liking the ride or the drop they got with the Roush springs.
Old May 17, 2010 | 10:02 PM
03blue6er's Avatar
03blue6er
i like your idea a lot since i do not want to spend a ton of money on the lowering and i want to be able to do it myself. Will it have as much of an improvement over stock.
Old May 17, 2010 | 10:36 PM
Shaunmac9128's Avatar
Shaunmac9128
It will handle and look better. Less of a drop. Not a bad choice. Cheaper too.
Old May 18, 2010 | 07:46 AM
03blue6er's Avatar
03blue6er
thats what im gona do. i dont want to worry about caster camber plates or anything like that.
