engine worries
Old Jun 13, 2010 | 02:10 PM
elvis1985's Avatar
elvis1985
well i have now cleaned the maf sensor but still doing it. is there anyway off resetting the ecu.
Old Jun 13, 2010 | 03:52 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Disconnec the battery for about 10 minutes and the code should clear
Old Jun 14, 2010 | 01:21 PM
XtremeOracing's Avatar
XtremeOracing
When in neutral the car will hit the rev limiter pretty quickly and i think its even lower than the standard rev limiter. Might be that; I can't watch the videos; i am on my phone!
Old Jun 15, 2010 | 10:49 AM
elvis1985's Avatar
elvis1985
well i disconnected the battery for 30 mins last night but still made no difference. thik i am going to have to look inside the rocker cover to see if we can see any broken springs etc.
Old Jun 16, 2010 | 04:51 AM
smallz33's Avatar
smallz33
mine was doing this but kinda backawrds whe nit wanted to stall out under 500 rpms it would make a wierd noise on the driver site like a rattle.. what were the codes coming up as? could be your valve seats and sticks open while theother one is opening.. kind of sounds like detonation issues at higher rpms but i could be wrong.. I has a vaccum leak to pcv and i for got to put bolt back on and tighten it because it slid way down the metal tube and never realized it was there till i tore it back apart..another thing could be warped head possibly.. deffinatley chech the valves though but try cleaning your idle air control valve first this also helped mine allot... i get to four grand in the rpms and it feel like my car shot nos in the system lolol then it could be as simple as your rev limiters .. try the cleaneable and easy thngs first.. because tearing the head apart isn't the funnest thing to do..well i like it its fucn to diassemble and reassemble but it is a pain in the ***...but the detonation would be caused by the timing.. but if it runds good under four grand i dont see why the timing would be bad,, could allways do a monster v8 swap lol... i was allways wondering if we could put smallblocks with a carb on instread of this fuel injected bull**** now days... bothing like a good old motor.. minus all the bullspit electical
Old Jun 17, 2010 | 04:46 PM
elvis1985's Avatar
elvis1985
ok i give the idel control valve a clean and then is all about cleaned etc. i have changed the oil last night so was hoping that might of helped but no, its still the same. There was no trouble codes that had being bought up
Old Jun 17, 2010 | 06:52 PM
Fink's Avatar
Fink
Could it be starving for fuel over 4K rpms? Motor mounts?
Old Jun 17, 2010 | 10:40 PM
Dan9687's Avatar
Dan9687
Whens the last time you checked the plugs? If you find oil on any let me know, I prolly know your problem....normal plugs that have been in use typically are ash/light grey in color.
Old Jun 18, 2010 | 11:11 AM
elvis1985's Avatar
elvis1985
we changed the plugs a couple of weeks ago. as far as i can remember there wasnt any oil on them. I cant remember how suited they were but i see if i can find them if we still got them
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
