Installing BBK Headers
Old Jun 8, 2010 | 03:04 PM
nexus08's Avatar
nexus08
I've seen the tech article on using the 96-98s. Sounded like some potential grinding and what not would be needed, which sounded like more hassle than I wanted to deal with.
The BBK's were only $270 w/ free shipping which wouldn't be too bad if I can get them installed myself. Long tubes would require the replacement of the Y-pipe (not sure that's what it is called) as well, and since that is where the catalysts are, I'm betting that gets real expensive. And like I said, I'm not looking for performance gains, just the ability to drive it in the winter without the exhaust choking me. If I can get a little more HP and MPG, all the better.
Back to the purpose of the thread, I think my next step will be to take off the Y-pipe. That should get me some more room underneath to work with.
Since this is a common problem with these models, I was hoping to get some advice from those who have replaced them. Even if you've just put in 96'ers, you must have had to do more or less the same task.
Old Jun 8, 2010 | 03:24 PM
neo8222's Avatar
neo8222
Originally Posted by brent4
^ and the BBK are expensive...it would be cheaper to get a set of 96-98 v6 mustang headers and put them in.
yeah just watch who you buy them from, i bought a set off a 94 and i was told they were in GREAT condition... i got them 2.5 MONTHS LATER! and they are warped and in awful condition. the passenger side leaks so much at the heads im thinking of taking it off and putting my cracked stocker on till i can find another passenger side.
Old Jun 8, 2010 | 04:03 PM
Fink's Avatar
Fink
Neo I have a set of stockers. Name your price with shipping.
Old Jun 8, 2010 | 04:18 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
You wasted your 270$ , you could also mate long tubes to your Y if you really wanted to.
Old Jun 8, 2010 | 04:33 PM
TurtleSLow's Avatar
TurtleSLow
when i replaced my stockers for LTs, i dont remember having a problem getting them out from the car, did you take off the air intake hoses to have better access to the headers? i cant remember if i pulled them out from the top or the bottoms to be honest, but maybe something to try is to jack the whole engine up a few inches maybe that will help, thats how we got a set of BBK shorties out of my buddies 91 5.0
Old Jun 9, 2010 | 12:13 AM
beerman4679's Avatar
beerman4679
Wow some definite ball busting here... Anyways I did get BBK headers too to replace cracked stock headers.
For replacing the drivers side, I completely removed the h-pipe like you said, not hard just another two bolts more than u already have to take off and you have to unplug the oxygen sensors (this was kinda a pain). Also, I'm assuming you took the dipstick out too. Then its not that bad. They are definitely shaped differently than the stock pipes and I just wasted time before giving in and accepting I had to take off the h-pipe.
For replacing the passengers side, I don't remember it being that bad other than having to take off the egr pipe completely, but mine wasn't rusted badly and stuck or anything. This is came out and went in from the top.
Hope this helps
PS there is also a guide here
http://lib.store.yahoo.net/lib/musta...rs-install.pdf
Old Jun 9, 2010 | 01:41 PM
neo8222's Avatar
neo8222
the driver side seems to have bolted up and fits right so im just going to wait till i see a single passenger side on ebay and snag it plus im looking for a 94-98 v6 header not our headerish POS lol
Old Jun 9, 2010 | 09:48 PM
Fink's Avatar
Fink
Well I could get you one of those too. Just have to make the hour long trip to the mustang only salvage yard.
Old Jun 10, 2010 | 01:21 PM
neo8222's Avatar
neo8222
i actually got one of those about 5 miles from me but yeah i MAY not have to replace it, the leak is smaller than it was before so I'm thinking if i over torque it and then run a few heat cycles back off the bolts and torque it again a few times i may be able to conform the header to the engine and get it nearly sealed up. worth a try anyways.
i was actually able to replace both from the top on the engine bay in about 30 seconds each side so it can be done just gota know how to turn the headers
Granatelli Sales
Jan 20, 2020 12:34 AM
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Luke9222
Sep 4, 2015 06:46 AM
cbird1177711
Sep 3, 2015 08:43 PM
