Air Conditioning Problems
Old Jun 11, 2010 | 11:28 PM
walkinthedog09's Avatar
walkinthedog09
Default Air Conditioning Problems
I have a 2002 Ford Mustang V.6. My problem is that when i turn on the A/C, the cold air comes out of the vents as it is supposed to but when i accelerate or go up any incline or hill, it stops coming out of the the vents that blow on you and transfers to the vent that hits the windshield. I usually have to turn it off and start again. Anyone with this problem and what is the solution and probable cost to fix. Thanks in advance.
Old Jun 12, 2010 | 12:30 AM
JKs95stang's Avatar
JKs95stang
You probably have a vacuum leak along the firewall, or at the canister or somewhere in between. I would check the firewall first.
Old Jun 12, 2010 | 01:35 AM
walkinthedog09
thank you for your response, i'm kind of a novice at fixing cars, but i'll give it a go. what tools would i need and, what would i need to do to check for a leak. i really appreciate the input.
Old Jun 12, 2010 | 01:09 PM
JKs95stang's Avatar
JKs95stang
I have used carb or brake cleaner in the past if I suspect a leak. The idle will change if you spray a leak because it's sucking air and brake cleaner.
Old Jun 13, 2010 | 10:09 PM
walkinthedog09
Awesome, will try, thank you for your help.
Old Jun 14, 2010 | 03:02 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
sounds like your blend door actuator may be going out. It's the vacuum solenoid that controls where the air goes and it's on your a/c plenum.
Old Jun 14, 2010 | 03:41 AM
Daehawk's Avatar
Daehawk
Had a Ford Contour with a vac / vent problem. Had it fixed TWICE and it did it again. I just left it since it was defaulted to defrost lol. POS system. Miss the car not the vent
Old Jun 15, 2010 | 09:29 AM
minkoff2000's Avatar
minkoff2000
Smile
Can you be more specific about where this is located? My daughters car has the same symptom.
Thanks in advance.
djbigskrilla
Sep 20, 2022 01:04 AM
67STANGX2
Dec 28, 2015 12:17 PM
SYNY5TER
Sep 2, 2015 01:35 AM
DrunknRuckus
Aug 23, 2015 10:05 AM
