Engine Swap
Old Aug 6, 2005 | 07:40 PM
Guest
Guest
Posts: n/a
Default Engine Swap
I'm thinking of putting a 4.6, maybe out of a crown vic, into my stang. I'd need a trans, fuel pump, 8.8 rear, the whole 9 yards. Anyone done this before? Any tips, ideas, suggestions?
Old Aug 6, 2005 | 08:16 PM
ckthecerealkiller's Avatar
ckthecerealkiller
Default RE: Engine Swap
Here's a tip. You will get a better response out of the 4.6 forum. This is a 4.6 engine you are talking about.
But as long as I am here.....
You will need.
* The engine
* Full wiring harness from the engine
* All the electrical to the ECU and any sensors
* If you want to do the whole front suspension. You can get a full kit for $900 bux to beef up that front suspension.
* It would be wise to upgrade the brakes.
* Transmission would have to be upgraded and then you would need the wiring harness for that.
* An 8.8" rear end would be preferable because the stock 7.5" isnt as strong, probably only good up untill about 400-450 ft-lbs torque but it CAN be beefed up if you really didnt want to change. Auburn makes a great Diff for it.
* Exhaust off of a GT. The H pipe, headers, you know the whole shabang.
* Live in a state that will allow you to swap the engine in your car.
Somes states like California wont allow you to put an engine in a car that wasnt originally offered with it. So check with local laws first, you might be limited to a 4.6 2V or 4V. If you can only find a 2V then do the PI head swap which will increase your power to something like 265hp or around there, all you need for that is 99+ heads off a GT.
There are alot of other things that you will need to do for the swap.
This is just for starters.... I don't quite know everything you will need.
Old Aug 8, 2005 | 09:45 PM
98ponycar's Avatar
98ponycar
Man just keep your six and beef her up. Look at it this way. If you want a GT, you can get yourself one for a lot less expense and hassle rather than having to swap a ton of parts. Besides, if you beef up the six and smoke some 8's, you'll have them eating out of the palm of your hand.
Nick Oliver
Oct 17, 2018 04:22 AM
cardsrus1
19
Sep 15, 2015 08:37 AM
97SN95GT
Sep 13, 2015 09:45 PM
zachary1988
Sep 4, 2015 03:04 PM
Sep 1, 2015 08:16 PM
