help stereo install
Old Jun 15, 2010 | 09:13 AM
kman025's Avatar
kman025
Default help stereo install
what plugs into the red, white, black, and yell inputs????
link to picture of what i'm talking about
http://www.sonicelectronix.com/pictu...ture_id=245783
i know what it says to plug into each, but i dont know where i find each of these things...
everything else makes sense, kind of, but i just dont understand what goes in those
Old Jun 15, 2010 | 09:21 AM
ARicci6792's Avatar
ARicci6792
I could be wrong, but those are only for things like amps, tv's, and other stuff like that if you have any installed.
For my headunit (which isnt a touchscreen), I only had a red and white plug I believe, and it was for my stock amps.
Old Jun 15, 2010 | 09:22 AM
ARicci6792's Avatar
ARicci6792
P.S....youd probably have better luck posting this in the Audio section Although im trying my best lmao
Old Jun 15, 2010 | 11:32 AM
kman025's Avatar
kman025
you were right... nevermind that
the guy said there should be some wires some where in the car from the amps??? where would these be?
Old Jun 15, 2010 | 11:36 AM
rumtillidie's Avatar
rumtillidie
Those are for external amps like if you want to add subwoofers to your car...or a 4 channel amplifier for the speakers. The tv out rcas are probably to clone the screen to a TV.
Old Jun 15, 2010 | 01:40 PM
neo8222's Avatar
neo8222
yup any RCA cable on the head unit are for OPTIONAL equipment that is not required to make it function. the cable that detaches from the head unit with the bare wires are the ones to get connected to the factory harness, take it to a stereo shop ( a REAL one NOT BEST BUY!) and they can get it all attached for a small price. tell them what car you have and whether or not you have a mach 460 sound system. they can get the cable and make you a connector that will plug into the factory setup. it usualy costs $20-$40 i did my own but that's because i can solder and i know what the wires go to.
Old Jun 15, 2010 | 02:31 PM
JKs95stang's Avatar
JKs95stang
Yeah those are pre outs for amps, dvd players, etc...
Old Jun 15, 2010 | 03:25 PM
kman025's Avatar
kman025
well i matched all the wires... (for the most part...)
i now cant get the mounting whatever to work right... waste of a day lol
Old Jun 16, 2010 | 01:39 PM
rumtillidie
lol make sure the deck has a SWITCH/REMOTE wire (usually blue) otherwise the deck won't play the sound. I had a deck that didn't have one and the speakers didnt work.
Old Jun 16, 2010 | 02:32 PM
kman025's Avatar
kman025
help
what do i do with this?
i dont know what to do with it... i dont see anything to wire it to.
one of the colors, i think the two blues, say amp turn on
then the other two say amp ground
