header gasket replacement
Old Aug 20, 2010 | 09:59 AM
chuckd2008's Avatar
chuckd2008
Default header gasket replacement
i am on here for my gf she has a 01 v6 premium and since she has bought it has made a ticking noise which the dealership said was a manifold leak how hard is it to replace the gaskets and do anyone know where i can find a write up on how to do it.?
Old Aug 20, 2010 | 10:23 AM
PNYXPRESS's Avatar
PNYXPRESS
are you sure its the gasket. Sounds like you have a cracked manifold instead.
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
Its not the gaskets that leaking, its the exhaust manifold itself. The Edge Mustangs have a problem where the condinsation from the A/C leaks down onto the manifold causing it to split due to the hight temps of the exhaust getting suddenly cooled by the cold condinsation water. You can reweld the manifold, or replace them with a set of 1994-1998's that dont have that problem.
Matthew
Old Aug 20, 2010 | 10:33 AM
Synyster06Gates's Avatar
Synyster06Gates
Matthew
I think they are just ****ty design/material. I figured it was the AC when my first manifold cracked (passenger side), but recently my drivers side cracked as well, nothing drips on it...
Old Aug 21, 2010 | 09:17 PM
chuckd2008's Avatar
chuckd2008
ok so is it a pretty easy fix i have accesses to a welder and have descent mechanical skills is it something that is easy for me to do? and if not how much is she looking at to weld a new one on?
Old Aug 21, 2010 | 09:40 PM
Matt's 95 Stang
Resident Ginger
you can do it yourself if you can weld. If not. get a set of 1994-1998 heagers as they do not suffer from the same failure that the 1999 and up do.
Matthew
Old Aug 22, 2010 | 11:39 AM
chuckd2008's Avatar
chuckd2008
ok thanks for the insight. If i get bbk shorty headers will that also fix the problem? casue i'd rather just upgrade rather then replace?
Old Aug 22, 2010 | 12:50 PM
LilRoush's Avatar
LilRoush
BBK shorties...or any shorties suck and are a waste of time. Flow same as stock- not an upgrade.
Pull the manifold off, have it welded for $15 and put it back on.
Old Aug 22, 2010 | 08:36 PM
neo8222's Avatar
neo8222
or do it right and buy long tubes with a h pipe and MAC flowpath mufflers, done done done
Old Aug 23, 2010 | 10:08 AM
Matt's 95 Stang
Resident Ginger
unless his state has emisions control, then thats a no go...
MAtthew
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
Luke9222
Sep 4, 2015 06:46 AM
