Misfire with no codes
Last night I developed a miss at idle. I already have the P1507 code being thrown for the IAC gasket mod, So I didnt know if it was throwing a code.
Well today I took it over to my brother in laws and hooked up the scanner. Only code I have is the P1507 one. Unhooked the reader, started the car and hooked it back up, still only the one code.
Now I know that my wires are original from 99, but I tested them a few months ago and they all came back good(changed plugs too). Yes the wires could have gone bad since then but I tested a few other things. Pulled the wires off each plug individually to see which is misfiring. No change.
Now do I suspect the coil pack?
I suspect I am misfiring on 3 cylinders, goes *brump* normal *brum-brump* or *brump* normal *brump* normal *brump*.
It does backfire when I let off, not really bad but a light snap.
lincolnshibuya
Dec 8, 2015 04:37 PM
