Terrible gas mileage, please help?!
When my manifold was cracked, my gas mileage went to ****. I also got a code though, for one of them. I've had BOTH manifolds crack and it showed a significant drop in mpgs both times. The reason is because the o2 sensor reads lean so the computer tries to fix it by sending more fuel to the engine.
ELEKTRO-FIDE Moderator
Location: In Geo-synchronous orbit over redass' bathroom,
it's also worth checking your fuel lines to make sure you're not spilling gas somewhere. a bump hard enough to tear off exhaust can definitely damage other things under there.
I posted a reply in her other thread about this same issue:
https://mustangforums.com/forum/gene...ease-help.html
I'm leaning towards a vacuum leak or Mass Airflow Sensor failure/dirty, but who knows...
Yes. But it could also be possible that the check engine light bulb is blown. Don't know if her year has an LED bulb or a regular bulb.
if you hear a gurgling noise when you shut the engine off thats most likely an exhaust leak. I know when I shut mine off (Im running open mid-pipe atm) it sounds like a big grumbly fart... and if the noise is coming from the engine compartment then you're probably looking at a manifold leak. And that would result in what everyones telling you. the first o2 sensor controls A/F ratio so if theres a small leak it would run lean and the car would compensate by dumping more fuel into the charge. and i don't think you would throw a code until the the leak was so bad, and the mixture was so lean, it wouldn't be able to compensate for it. that's what I got out of what Synster said at least
i got a decent size leak right where the headers bolts to the heads on my car and it's never thrown a code. i'm also noticing a substantial amount of fuel economy loss. also never threw a code when the factory piece cracked the many times that they did.
Wow, took me a while to read all the replies, thanks a lot guys, I appreciate it. So what it all boils down to, from what I read, is it's either....
a) faulty 02 sensors that aren't throwing a code for w/e reason
b) cracked manifold that would cause? the o2 sensors to be thrown off
c) dirty/faulty mass airflow sensor
d) blown bulb in engine light
e) vacuum leak
f) fuel line leak somewhere (we don't see anything though)
thanks again!
e) vacuum leak
thanks again!
