Last edit by: IB Advertising
Browse all: Engine and Powertrain
- Ford Mustang 1994-2004: How to Flush Your Radiator
Step by step instructions for do-it-yourself repairs.
"Radiator Flush" question
Ok, so after adding some coolant to my car tonight I noticed a lot of brownish orange gunk floating in the coolant. So I guess I need to drain my radiator and add some new coolant but my question is, this radiator flush they offer at parts stores, does this stuff work? I read online that to use it you have to drain the radiator, pour the container in and fill the rest of the way with water, run the car for 10-15 mins, then drain again and add new coolant. However it said not to use on an aluminum radiator. Do our cars use aluminum radiators?
also does anyone have a decent pic of where this vent plug is for refilling the cooling system? I read a little here and there but not 100% sure where it is
EDIT: Make sure to purge all the air out of the coolant system via the bleeder screw towards the waterpump!
If it's too bad just get a new one, they run about $90 new down here in South FL.
I believe using 50/50 mix gives you a better cooling, but less protection against freezing.
Boiling Protection
Formula Celsius(Fahrenheit)
50% 1:1 (1 part antifreeze/1 part water) 129.4(265)
Freezing Protection
40% 2:3 (2 parts antifreeze/3 parts water) -24.4(-12)
50% 1:1 (1 part antifreeze/1 part water) -36.7(-34)
60% 3:2 (3 parts antifreeze/2 parts water) -52.2(-62)
Boiling Protection
Freezing Protection
Better cooling, higher boiling point, lower freezing point, the coolant also acts as a lubricant for the water pump, and helps prevent rust inside the engine block.
Ok so ive narrowed it down to the hoses so it looks like sunday im going to flush my radiator and replace the upper and lower hose. Now I was reading in my Haynes manual it says to drain the coolant out of the drain block plugs located just above the oil pan on either side of the motor.... is this necessary?
