Headlights
Old Dec 31, 2010 | 04:37 PM
1998redstangg's Avatar
1998redstangg
Default Headlights
Just joined the Mustang society. Purchased a basic 1998 V6. Having trouble with the headlights. The high-beams work, but the low-beams don't. All other lights work. Are the low-beams on a separate circuit or fuse?
Old Dec 31, 2010 | 06:17 PM
2005Redfire6's Avatar
2005Redfire6
Welcome... You will find better answers in your model year specific section.
Old Dec 31, 2010 | 06:54 PM
lizzyfan's Avatar
lizzyfan
Underboss
Moving
Old Dec 31, 2010 | 07:13 PM
LilRoush's Avatar
LilRoush
I like how headlights became a V6 specific topic.
Chances are the bulbs are shot. The first thing I'd do is pull them out. Check the bulb and the wiring into the back of the connector. Sometimes you'll find loose/worn out wires at the clip.
Old Dec 31, 2010 | 07:25 PM
Daehawk's Avatar
Daehawk
Not to steal the thread and to stay on headlights. Is there a cheap place to get the little slides that hold the head lights in place? Both mine are missing one and it's affecting my ability to aim them. They are too low and wont raise up. I have drive with them on high all the time to see more than 5 feet. And no one brights me.
Old Dec 31, 2010 | 08:15 PM
petrock's Avatar
petrock
+1 If the bulbs and connectors check out, get a volt meter and make sure that the light is getting power when in low beams (12 gauge light green & black wire is power for high beams, 12 gauge red & black wire is power for the low beams, 12 gauge black wire is ground for both). The high beams are on a separate circuit then the low beams that both get power through the multi-function switch in the steering column.
Good luck...
Old Jan 1, 2011 | 12:30 PM
mustang99v6's Avatar
mustang99v6
cheap? how about free? walk around a junkyard and pull some from a junker. Puts them in your nasty little pocketses.........
Old Jan 1, 2011 | 05:04 PM
NeoTokyo's Avatar
NeoTokyo
Thats what I thought too. :P
If you still have this problem when you change the bulbs then you could have a failing muli switch (The whole turn signal, wiper hi/lo beam unit.)
The wires pass through a pinch area and over time are cut.
StalkerGT
Nov 28, 2015 03:09 PM
Seanam
Oct 4, 2015 10:15 AM
Drastang
Sep 29, 2015 03:31 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
