98 tang
Old Jan 30, 2011 | 07:55 PM
bfbiker's Avatar
bfbiker
Default 98 tang
Wife has a 98 convertibles I got her for xmas .Turned ou it needed a lot of work but is well worth it any way,got a new top and frame out of N.C. and with shipping was around 450. got the slaves and pumps with it (make money back on them) anyway they put Projection beams in it and well they suck,I need to know what fuse is for the dash lights (no fuse box cover) If someone could post a pic of the lid that shows where the fuse are would be great ( no yards around here have one ,so I can't just pick one up. Also I'm putting the stock lights back in but they cut the all the plugs off and wired in the P lights in,what cars will work for the plugs
Thanks and sorry its so long (give me a old tang a harley or a moto-guzzi and I can make it do anything but dam this new stuff
Old Jan 30, 2011 | 08:25 PM
donnieb83's Avatar
donnieb83
Welcome? Think I read a LONG sentence with 10 different ideas...lol.
Old Jan 30, 2011 | 09:05 PM
bfbiker's Avatar
bfbiker
Default Hey I.m a dam old biker
Yep long and I really need to know where the dash light fuse is on the panel
so a pic of the cover that shows where the fuse' are at would be grat help our what cars I could get a cover from that would be the same
Thanks again
Phil
(I'm also on the ford truck site for many years so if ya need help with a truck just ask me .If its got a F in it I can make it run(oh and bikes too)thanks for the wecome and hope to meet people around the Washington St.area
Old Feb 2, 2011 | 01:06 AM
petrock's Avatar
petrock
The instrument cluster's fuse is fuse #15, and the instrument cluster's dash lights are #13. Both are in the fuse panel under the steering wheel, and both are 10 amp fuses. Sorry, my camera is broken at the moment, otherwise I'd climb under my girly's stang and take a pic for you.
btw, the fuses are described in the owners manual. If you don't have it, you can pick one up off ebay for pretty cheap.
As for the headlight connectors, check out rockauto.com. They have them in stock (between $2 & $19 depending on manufacturer). If you use their "interactive" catalog, you can get a cross reference of what other vehicles the part will work on. The headlight connector is used on a TON of years/model fords. So your local junk yard may have one of them available that you could pull the connector from.
Good luck...
Old Feb 2, 2011 | 07:34 AM
bfbiker's Avatar
bfbiker
Thanks Petrock,That helps alot
Now all I have to do is fix the head lights and hopefully that works
Thanks again
Hogquad
Aug 23, 2015 05:26 AM
MikeHawke
Mar 28, 2010 02:28 PM
99gt302
Mar 10, 2008 11:27 PM
ms.tangGT
Chop Shop
Jun 4, 2007 06:31 PM
macdaddyslomo
Jun 16, 2006 02:19 PM
