s.e.s. code p0401
Old Jan 31, 2011 | 07:32 PM
juancvilla's Avatar
juancvilla
Default s.e.s. code p0401
hi guys i got the service engine light on and its giving me the code p0401 for insufficient egr flow. now after reading online that more than likely it would be the dpfe sensor and i replaced it with one from autozone (duralast) and after 15 minutes of driving the light came back again. i aso tried cleaning the egr valve reset the code and its back again any other ideas i already checked and all the lines look good.
Old Jan 31, 2011 | 07:48 PM
NeoTokyo's Avatar
NeoTokyo
You should give Seafoam a try to clean out those EGR bungs.
There is an EGR bung in each long runner on the lower intake, those can cake up over time closeing the tiny hole.
The most effective way to clean them is to remove the upper intake and clean them by hand.
Its also a great idea to do a major engine detal at the same time, be sure to block off the runners with duck tape so no water can get into the runner.
Its a good idea to put a rag or sponge in each runner in case a little water gets in.
Clean the upper intake out really well as well and check over all sensors.
Its like doing spring cleaning.
Old Jan 31, 2011 | 07:52 PM
NeoTokyo's Avatar
NeoTokyo
When I ported my upper and lower intake on the 2000 motor that I bought for the swap into the 96' the EGR bungs were almost completely closed, a couple were infact.
Old Jan 31, 2011 | 08:33 PM
juancvilla's Avatar
juancvilla
hi sorry i lied my vacuum lines are not ok one of them was actually making contanct with the line to flush the antifreeze i just cant remember the name now. and it was just melting so how can i replace that line is the long one to the intake
Old Feb 2, 2011 | 01:04 PM
l_shizzle_l's Avatar
l_shizzle_l
...get a new vaccum line at autozone? which one is it?
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
