Slight overheating issue
Old Feb 2, 2011 | 08:26 PM
gusguts44's Avatar
gusguts44
Default Slight overheating issue
Having an issue with the car (2000 Auto) overheating when stuck in traffic or waiting at a drive-thru for a long period of time. The car will gradually begin overheating, but as soon as i get back on the road the needle returns to normal. I dont know if this is related but my heater also goes off and on, works fine when driving but if i stop will blow cold air. Planning to replace the thermostat this weekend, also want to to a radiator flush but i keep reading different techniques on how to do so. The haynes manual shows me one way, this link http://www.mikefordmustang.com/write...on-mustang.php shows me another. Any help on the above problems would be great thanks
Old Feb 2, 2011 | 10:59 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Get the Prestone radiator flush and follow the directions on the back, after you flush it, change the thermostat with a factory unit.
Old Feb 3, 2011 | 02:12 AM
petrock's Avatar
petrock
If it cools down while your driving, and heats up while your stopped, then its probably your electric cooling fan. When it heats up when stopped, do you hear the fan kick in? If not, there's your problem.
The radiator flush etc is still a good idea though, especially if it hasn't been done in a couple years.
Old Feb 3, 2011 | 04:24 AM
NeoTokyo's Avatar
NeoTokyo
+1 to the fan.
+2 to doing the flush anyways.
To test if your fan works set your A/C to MAX and check to see if its on.
Your fan will always come on when the A/C is set to MAX. If it does not then you have a bad fan.
BOB ROME
Jul 26, 2023 01:54 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
