does zinc plating make any difference?
Old Feb 8, 2011 | 10:36 AM
TonyO's Avatar
TonyO
Default does zinc plating make any difference?
just bought my first mustang and the brakes need to be replaced, looking into getting cross drilled and slotted rotors, and came across some zinc plated ones. does zinc plating make any difference or is it strictly a cosmetic touch to keep the rotors shiny? also what should I expect to pay for a decent set of those rotors?
Old Feb 8, 2011 | 01:05 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
It's a plating, which means it's on the surface, the surface which is scraped away by using the brakes. Make your own conclusions about wether you think it's worth it. Cryo treating is the only thing worth doing.
Old Feb 8, 2011 | 02:11 PM
Warthog5's Avatar
Warthog5
It will keep the areas that are not touched by the pads from rusting. Where the pads touch the coating will be removed.
Old Feb 8, 2011 | 11:10 PM
RyansQuick6
Reverse Gear Member
I accomplished that with black high temp paint lol
Old Feb 9, 2011 | 01:35 AM
petrock's Avatar
petrock
+1. PowerSlot rotors take care of it with black powdercoat.
Old Feb 9, 2011 | 02:28 AM
robb15033's Avatar
robb15033
Yes, the zink coating keeps everything looking original as time goes by. No rust.
Granatelli Sales
Jan 20, 2020 12:34 AM
Bullet 67
Sep 18, 2015 08:00 AM
MustangHead91
Sep 15, 2015 09:07 AM
ak98
Sep 10, 2015 10:33 PM
Bullet 67
Aug 24, 2015 07:02 AM
