gauge cluster colors
for the gauges im sure its a pita. i removed the green film behind my hvac and shifter, but just went with a mach 1 cluster since they dont have any film, just the white reverse side. here is the write up from AM showing how to put on reverse glow gauges http://www.americanmuscle.com/mustan...es-how-to.html take note that your cluster wont have the screws to remove the lens over the gauges, they are plastic welds, making this even harder to do.
what color do the 99-00 gt clusters have?
edit:
what gauge cluster is this?
edit:
If you want it to come out looking bright use the cool white since it has the highest intensity. But Elias is right if you change the dash you should also change the HVAC lights because it would look weird to have it different colors.
here's how it looks with the cool white
In his guide he says "The gauge cluster and HVAC controls you will see in the following pictures or the first pictures are not aftermarket, not reverse-glo, not special edition or anything else. My gauge cluster and HVAC controls are the ones that were installed in my car from the factory." But I think that's a TOTAL lie...
I think it's actually a White Face Gauge Cluster that you can find here:
http://www.americanmuscle.com/mustan...it-9904v6.html
also because my gauge's are black, and my numbers go in 10's: 10,20,30.. his goes in 20's: 20,40,60...
I think maybe he just bought it that way and thought it was stock? I've never seen a Mustang with that gauge stock.
i cant find any stock gauges from 94-04 that have a redline of 7k. some of the sn95 cobras come close, but they are white faced. the mach 1 also comes close but the numbers look way different than that. hmm roush or saleen?
