Passenger window problem..
Old Feb 13, 2011 | 02:13 PM
DigitalTrixx's Avatar
DigitalTrixx
Default Passenger window problem..
Hello again... Searched through the forums but couldn't find a good answer for my specific problem.
Problem : Passenger window does not roll UP from driver side.
Works fine when rolling it up / down from passenger side, and rolls down fine from driver side. Read that it may be my switch? but how do I test to see if that is the problem.
Old Feb 13, 2011 | 07:29 PM
03shadow's Avatar
03shadow
do you think the motor could be going out?
Old Feb 13, 2011 | 07:51 PM
DigitalTrixx
Highly doubt it, works perfect, even rolls down slightly faster then my driver side.
Old Feb 14, 2011 | 08:00 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
The switches actually pull out of the panel that they're attached to, so just switch them around on the driver's side and see what it does.
Old Feb 16, 2011 | 09:17 AM
MustangSally94's Avatar
MustangSally94
its probably just the switch going out... like Ryan said, pop the one off the passanger side and swap it with one on the drivers side to test it and if it solves the current problem find one in a junk yard
Old Feb 17, 2011 | 01:44 AM
petrock's Avatar
petrock
+1 on the drivers side switch.
Old Feb 25, 2011 | 03:18 AM
NeoTokyo's Avatar
NeoTokyo
Did ya ever get it fixed?
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
UrS4
Oct 3, 2015 06:23 AM
Sixer4Life
Sep 29, 2015 07:03 PM
