2001 abs light question?????????????
Old Mar 8, 2011 | 07:13 PM
TEXASGT/CS's Avatar
TEXASGT/CS
Default 2001 abs light question?????????????
actually 2 questions, does the abs light being on have anything to do with the traction control light coming one, second question, how hard is it to replace the abs sensor. ok third question, is there a sensor on each wheel.
thanks in advance.
Old Mar 8, 2011 | 07:27 PM
mustangman02232's Avatar
mustangman02232
one on each wheel, and the TCS is tied into the abs system, if you have no abs the TCS will not work, i dont see how it can be to hard to replace one, i never had to though
Old Mar 8, 2011 | 08:43 PM
jthorn9's Avatar
jthorn9
The Godfather
I agree, while I've never changed one, I can't imagine it being all that hard, I've changed out a lot of stuff in the brakes/suspension and a sensor can't be all that hard.
Old Mar 9, 2011 | 08:59 AM
TEXASGT/CS's Avatar
TEXASGT/CS
SOOOOO. how do you determine which one is bad? I guess that is the million dollar question.
And thanks again.
Old Mar 10, 2011 | 04:27 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
That is the million dollar question. Do you have a CEL? If so pull the CEL and see if it tells you which one is bad.
Matthew
Old Mar 10, 2011 | 08:24 PM
NeoTokyo's Avatar
NeoTokyo
Check em to see if they are all crudded up first, they are however easy to swap.
Old Mar 11, 2011 | 03:25 PM
Matt's 95 Stang
Resident Ginger
This. If you live or driver someplace with heavy rain and mud the "ring" get plugged up and throw a CEL. You can clean them off and might fix your problem with no money spent.
Matthew
Old Mar 11, 2011 | 04:31 PM
TEXASGT/CS's Avatar
TEXASGT/CS
thanks so much for the help guys, i will take a good look at them this weekend.
cardsrus1
19
Sep 15, 2015 08:37 AM
97SN95GT
Sep 13, 2015 09:45 PM
AMAlexLazarus
AmericanMuscle.com
Sep 2, 2015 08:59 AM
GimpyHSHS
Aug 29, 2015 06:30 PM
gagemcc
Aug 26, 2015 12:37 AM
