error code po352...
Old Apr 19, 2011 | 08:16 AM
jlc41's Avatar
jlc41
Default PCM
Originally Posted by bbutt41151
ok, heres the skinny for u ....when a scanner gives u a code po350 thru po362, that means the coil is not receiving the proper firing directions from the ecm (pcm). when ever u get a code po350 thru po362 (assuming a 12 cylinder engine) it means the coil driver circuit in my pcm was indeed fried. so ,yes it was definately a maintenance issue,which i did admit in my first post. so the smart *** answers dont surprise me from someone who is barely literate.....if thats your normal input on an issue...keep it to urself...all it does is alienate people.........SOON TO BE FORMER MEMBER OF THIS SITE!!
Glad you got it sorted out. I learned some more about these newer cars. I will have to get a handle on the codes. Thanks
Old Apr 19, 2011 | 09:11 AM
jthorn9's Avatar
jthorn9
The Godfather
I'm glad you discovered your problem but there was no need to make such a rude second post. Just because a thread gets a lot of views doesn't mean they were by site members but rather guest. On the forums it has become a common trend where if you don't know then keep your mouth shut so that bad information isn't given out. Congrats on finding your problem but if you come back then please refrain from such rude comments.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
ChampInSD
Oct 2, 2015 04:55 AM
