AC Question... need help!
Old May 3, 2011 | 01:50 PM
MustangSally94's Avatar
MustangSally94
Default AC Question... need help!
So my AC stopped blowing out of the vents on the dash. It now blows out of the defrost only. I read on here it could be a vacuum leak, but how do I trace it down.
I coppied the following quote from another thread on the same issue but im not really clear on where this area hes talking about it.
Originally Posted by RyansQuick6
Most likely, the "blend door actuator" went out. It's what controls were the air flows by a vacuum operated solenoid that opens a little door in the a/c plenum.
Thanks for all your help!
Old May 3, 2011 | 02:19 PM
jthorn9's Avatar
jthorn9
The Godfather
The leak is at the vacuum harness inside the engine bay. It's located in the back of the engine bay on the drivers side, should be about 4 or 5 hoses that plug into that little assembly. If one pops off it will cause the problem you're having.
Old May 3, 2011 | 02:22 PM
MustangSally94
yea I found a hose that was broken off, a little tiny pastic one... I fixed it and still nothing... I guess next is to check the hoses under the dash?
Old May 5, 2011 | 08:31 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
Mine did the same thing. Turns out the smallest hose (I believe the bottom hose off the vacuume tree) had cracked due to age and had to be replaced. That hose runs across the firewall and into another unit on the pass side.
Matthew
Old May 7, 2011 | 10:09 AM
MustangSally94
yea I got in the car the next day after I fixed the hose and it started working... maybe it just needed to build enough pressure for the solenoid to click? I dunno lol, my car is like a woman... temperamental!!!
Old May 7, 2011 | 11:23 AM
Matt's 95 Stang
Resident Ginger
ALLLLLLL single-ports are tempermental for some reason...mine acts up just about everyother month haha. Glad you got it fixed.
Matthew
Old May 7, 2011 | 11:51 AM
jthorn9's Avatar
jthorn9
The Godfather
All cars are tempermental period lmao.
Dalthius
Jan 19, 2006 03:56 AM
Scooterman
May 12, 2005 11:44 AM
black89gt
Mar 12, 2005 08:08 PM
SCARFACE
SVT Forums
May 6, 2004 05:12 PM
karma279
Oct 27, 2003 07:18 PM
