help!!!!! misfiring or fuel problem???
Old May 16, 2011 | 04:59 PM
Cj02stangV6's Avatar
Cj02stangV6
Default help!!!!! misfiring or fuel problem???
hey guys. let me just start by saying i have already changed the mass air flow sensor, plugs, wires, and ignition coil, pcv valve, and fuel filter and i just put fuel into the car right before this problem started to happen. ive just ran into a problem on my mustang over the weekend. the car is running like total crap, it is idiling really bad but above 2000 rpm is runs fine. its throwing a check engine light for po303 and po316 which i know is a misfire on 3 and a misfire on start up . so i went ahead and bought a new set of spark plugs and put them in sunday night. still not running right and still throwing the exact same codes. and so i talk to a buddy of mine and says maybe i got water in the fuel. so im gonna run some isopropyl alcohol through my fuel system to see if thats will clear any water i might have in the system out. is there ANY other ideas you guys would have that could solve this problem?? any help would be awesome thanks! Chris
Old May 16, 2011 | 05:30 PM
SON1C's Avatar
SON1C
you more than likely have the wires crossed, the coil pack is
1 2 3
4 6 5
i think. someone can correct this if its wrong.
Old May 17, 2011 | 06:10 AM
Cj02stangV6
It ran fine for about a month and a half after I did all the wires,plugs, and ignition coil etc.... Like I said this just started this past weekend. Anything else yall can think of???
Old May 17, 2011 | 09:37 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
What brand of coil and plugs did you install? Have you checked the wires for any damage?
Old May 17, 2011 | 12:16 PM
Cj02stangV6
Duralast coil from autozone. Motorcraft plugs. Bosch wires. Ill have to see if any are damaged. Thanks
Old May 17, 2011 | 08:37 PM
RyansQuick6
Reverse Gear Member
Get a motorcraft coil
Old May 22, 2011 | 02:09 AM
2004V6coupe's Avatar
2004V6coupe
My coil pack reads as follows:
123
564
I had the same problem initially after changing my plugs and wires the other day. I simply switched #4 and #5 wires on the coil pack. It idles great now, but I still have a slight sputter when revving at high RPMs especially uphill. It doesn't happen all the time though.
StalkerGT
Sep 25, 2015 02:41 PM
bconboy
Sep 21, 2015 12:52 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
SYNY5TER
Sep 2, 2015 01:35 AM
