help with my CAI
Old Sep 2, 2005 | 09:37 PM
Seanohue's Avatar
Seanohue
Default help with my CAI
I have everything installed on my CAI except the filter because I cant find where it is that it attaches to in the well of the car. Am I supposed to remove the gaurd in the well?
Old Sep 2, 2005 | 11:22 PM
Crzybiker's Avatar
Crzybiker
Default RE: help with my CAI
The tubing should go from the TB to the MAF then from there it goes down and most make a right angle turn into the the hole next to where the old airbox sat and the air silencer went in. Most if not all kits should come with a large plate to cover the hole and give support to the intake tubing, the filter will mount inside the fender and is usually attached with something along the lines of a band clamp. You will have to remove the inner wheel well which is held in by those push-pin things. Hope that helps sorry if it doesn't
Jb145700
Aug 21, 2022 06:37 AM
baddog671
Jul 26, 2016 01:20 PM
mapitts
May 15, 2016 02:57 AM
junior04
Sep 28, 2015 10:53 AM
firecoyote
Sep 27, 2015 02:37 PM
