Help with Mach 460
Old Jul 11, 2011 | 01:22 AM
hencethealec's Avatar
hencethealec
Unhappy Help with Mach 460
Hi, I'm new to the forum, so this might have been answered before.
I just bought a 2001 3.8 with the mach 460 system. After I purchased, I found out that the previous owner had for some reason cut all the stock plugs behind the head unit and wired in some crappy cd player in place of the stock deck, and they didn't even use a wiring harness. I probably should have tested out the stereo before I bought the car but I was more interested in out it was running. The only speakers that are currently working are the tweeters on the doors by the mirrors, and they aren't even working that well. My question is, where should I go from here? Is this something I might be able to take care of myself or should I take it to a shop? Thanks in advance!
Old Jul 11, 2011 | 09:25 AM
LilRoush's Avatar
LilRoush
What they did was remove the factory amps from the circuit. If you run an aftermarket stereo into them, your sound gets worse. The only speakers that aren't amp'd with the Mach 460 are the door tweeters.
Two options for you.
1) Find the stock head unit and try to match wires up. Double check to make sure the stock amp rack/speakers are still under the package try in the trunk as well.
2) Buy new (4 ohm) speakers for the stock locations and run your own wires to them.
Old Jul 11, 2011 | 09:30 AM
d.girardi's Avatar
d.girardi
I've got two kicker 5x7's ill send you if you pay shipping. One has a small tear but they still sound okay. Just an option.
Old Jul 11, 2011 | 10:09 AM
d.girardi's Avatar
d.girardi
Old Jul 11, 2011 | 08:32 PM
desertt5's Avatar
desertt5
You could wire factory plugs back in if you have patients and really want the 460 back. All the wire colors and diagrams are on here.
You would get more bang for you buck by going with lilroush's option 2.
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
