I cant figure this out. I over heated today poppd the engine codes forget what it was. My ac went from ice cold to hot as hell. the guage was in the hot range. I put in a new t-stat. went for a driver and still over heating. I need help. I will check the fans in the am. But do these cars have a problem with this? Any help would be appreciated.
If it overheats when sitting at a light, then that suggests the fan isn't working or isn't working as well as it should... Flushing and refilling the coolant isn't a bad idea either, especially if it hasn't been doe in a couple years. Good luck...
thanks guys no I did not bleed the system fter the t stat change. I will check the fan. Seem to get really hot after the A/Chas been on for a minute or to.
