brake problem. help please!
Old Jul 24, 2011 | 09:11 PM
picky's Avatar
picky
Default brake problem. help please!
have an 04 3.8L with about 25k miles on it
changed the brake pads and bled all the lines. start up the car and the pedal goes all the way to the floor.
possible causes???
i see a "bubble" in the master cylinder as well. not sure what else is going on to cause the pedal to sink close to the floor and feel squishy..
Old Jul 24, 2011 | 09:21 PM
picky's Avatar
picky
and does air get caught in the brake lines that angle upwards?
Old Jul 24, 2011 | 09:26 PM
95SHO's Avatar
95SHO
Why did you bleed the brakes when all you did is replace pads? When bleeding them did you let the MC get totally dry?
Old Jul 24, 2011 | 09:50 PM
picky's Avatar
picky
my brake fluid was dirty(as in pretty dark). so i did it all the same time. no we kept it wet the whole time.
Old Jul 25, 2011 | 01:25 AM
picky's Avatar
picky
any suggestions would be nice....
Old Jul 30, 2011 | 07:58 PM
petrock's Avatar
petrock
After bleeding the brakes, you need to pump the brake pedal a couple times to build up pressure in the system again and refill the piston inside the master cylinder. That is normal. If, however, it is still hitting the floor after you have pumped the brake pedal a bunch of times then you have a separate issue. Maybe air got into the system somehow, or a failed master cylinder, or a leak somewhere.
Good luck...
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
