chamber ajustmen
Old Jul 31, 2011 | 01:48 AM
mbabbitt's Avatar
mbabbitt
Default chamber ajustmen
grrrrrrrrrr i had a new lower ball joint put in 3 months ago and now i am wairinrg out the inside of my tire,,, did thay do somthing wrong ? if not how do you ajust the chamber .. might it be my strut going bad ??/
Old Jul 31, 2011 | 02:56 AM
robb15033's Avatar
robb15033
Three months is a short enough time to expect them to look at it for free. After they installed the balljoints, they aligned it. Negative camber wears inside of tire.
Lowering springs usually require caster camber plates. A camber bolt set is like $20.00 if a slight adjustment is needed.
Sometimes X-2 balljoints are needed to raise spindle geometry. Steeda can be contacted by phone to discuss whether or not they're appropriate or not.
-Let us know if its a quick fix. Good info to learn.
Old Jul 31, 2011 | 04:41 AM
petrock's Avatar
petrock
Double post: https://mustangforums.com/forum/gene...ajustment.html
Old Jul 31, 2011 | 09:21 AM
03shadow's Avatar
03shadow
his car is probably at stock ride height. Im curious marty, how often have you changed the struts on the car? but yeah it probably needs an alignment
Old Jul 31, 2011 | 08:04 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Hub bearing could also be the culprit.
FivePointToTheOh
Mar 9, 2020 10:26 PM
drfister
May 3, 2018 10:38 PM
uberstang1
Sep 20, 2015 06:42 PM
Sep 10, 2015 08:39 PM
Turtle
Oct 12, 2003 12:06 AM
