A/C hose help needed please!
Old Aug 7, 2011 | 03:22 PM
mustanggrl480's Avatar
mustanggrl480
Default A/C hose help needed please!
I have an '01 3.8 and my a/c started blowing hot air. When I took it in, I was told the a/c manifold hose is leaking and they want to charge way too much to replace it. When I search for the part, I find no such thing as an a/c manifold hose, only discharge hoses and suction hoses. Any idea which I need?
Old Aug 9, 2011 | 04:23 PM
FCMustang's Avatar
FCMustang
There is no a/c manifold. There's an intake manifold, but if that's leaking then it wouldn't affect your a/c at all. You could just be low on freon. I would get a second opinion if I were you. Where did you take it anyway?
Old Aug 9, 2011 | 05:01 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
^This. You are probably low on R134 (we dont use Freon anymore) and just need a fill up. But you could also have a hose that is cracked and bleeding the cool air out of the system. There is a tool that will check for that IIRC, it puts blue dye into the cooling system to see if there are any leaks.
Matthew
Old Aug 10, 2011 | 12:15 AM
mustanggrl480
I took it to Brakes Plus. I asked them if they could still refill & recharge it but they said the hose was so bad it would just leak out right away.
Old Aug 10, 2011 | 08:38 AM
Matt's 95 Stang
Resident Ginger
OK. then you will have to replace the hose. Did they tell you which one is leaking? It shouldnt be to hard to replace.
Matthew
Old Aug 10, 2011 | 09:46 AM
mustanggrl480
No I called to clarify if they meant the discharge or suction hose and they are trying to tell me it's one hose that does it all. So I don't know what to replace.
djbigskrilla
Sep 20, 2022 01:04 AM
Omgitsa88Stang
Sep 1, 2015 06:31 AM
SANDY21
Aug 17, 2015 02:41 PM
defarmer
Aug 13, 2015 06:40 AM
HIS S-197
Aug 10, 2015 05:47 PM
