Pulley Torque Specs
Old Sep 13, 2011 | 01:50 PM
KUlmer's Avatar
KUlmer
Default Pulley Torque Specs
Hey gang...I'm about to install a set of BBK UD Pulleys on my 95 V6. The installation instructions only tell me to tighten the bolts to the factory specs, but they don't tell me what those specs are. Can anyone tell me what the factory torque specs are for the two pulleys? Also, should I use Locktite?
Thanks in advance! -Ken
Old Sep 13, 2011 | 06:20 PM
03shadow's Avatar
03shadow
you can probably go by asp's instructions
http://www.miracerros.com/mustang/pulley.htm
Old Sep 13, 2011 | 07:42 PM
KUlmer's Avatar
KUlmer
Thanks, Shadow. That helps, but I still need the torque on the Alternator Pulley. Anybody?
Thanks -Ken
Old Sep 14, 2011 | 01:29 PM
mustang99v6's Avatar
mustang99v6
I always use the german "ghudntite" method and red loctite. Mine has been on for 3+ years now with no probs.
Old Sep 14, 2011 | 02:04 PM
KUlmer's Avatar
KUlmer
Thanks. LMAO!
The Germans know a thing or two about cars. Right? That's the approach that always worked for me before I had a torque wrench. Now that I have one, I like it to earn its keep now and then.
Follow-up... The fine folks at BBK emailed me today that the recommended torque is 30-35 ft/lbs. for both pulleys. They also said Locktite is not necessary unless you have an impact wrench to remove them if needed later.
Old Sep 14, 2011 | 02:52 PM
03shadow's Avatar
03shadow
30-35 for the crank pulley? maybe a difference in year and manufacturer from the instructions i posted but i would still think that 35 is low
Old Sep 14, 2011 | 10:00 PM
KUlmer's Avatar
KUlmer
Thanks again Shadow. That does seem kinda low, doesn't it? On the '95, the Harmonic Damper is not one piece with the crank pulley. The swap is simply just the pulley. Maybe that's why? I learned from your instructions that it was in 1999 when Ford combined the harmonic balancer and the crankshaft pulley into one unit. For your year it seems that the bolt that holds the damper to the crankshaft torques to 115 ft/lbs. The bolts that hold the pulley to the damper get torqued to 45 ft/lbs, according to the link you posted. I'm assuming that the part that applies to my '95 is the Pulley to Balancer (45 ft/lbs) since my balancer never leaves the crank shaft? The bolts are pretty small, 1/2" I think. Am I understanding this correctly? Am I making too much of this torque issue? Is "gudntite" good enough? Thanks again!
Old Sep 14, 2011 | 10:32 PM
mustang99v6
Keep in mind, while I just go off of getting it nice and tight, I also feel that I have the "mechanics' touch". I've been turning wrenches for many a year now. So, I did go in sequence around on all the nuts little by little. Also, you will be dealing with aluminum, so be careful there. Good luck!
Old Sep 17, 2011 | 12:19 PM
03shadow's Avatar
03shadow
ok that makes sense. i thought that you were doing a harmonic balancer with it. if just the pulley then 45 should be fine
Old Apr 3, 2023 | 05:38 PM
Sys's Avatar
Sys
Default Pulley bolts
Now I know the torque spec, but my 98 broke the crank pulley and destroyed 3 of the bolts. I bought a new dampener but I need to know what the 4 bolts are, size and thread, can't find a reference anywhere, and this time they will be locktited.
Please Help, Thanks Sys
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
spdeplayer2
Oct 24, 2015 09:45 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
