Oil in Coolant??
I had a coolant leak on the passenger side water pump. I pull the water pump out and removed the studs. on the passenger side coolant comes out when i take the studs out. But when i pulled the stud out from the drivers side near the power steering pulley, it was covered with an oily sluge.
Is this normal or is oil leaking into my coolant? I cant tell from the coolant i drained if it is just dirty or if it has a light amount of oil in it. The stud i pulled out that was oily didn't apear to have any coolant on it either.
Thanks for your help
