heater switch
Old Oct 26, 2011 | 02:45 PM
GARY247's Avatar
GARY247
Default heater switch
My heater on my 97 3.8 coupe is stuck on defrost. Since it is pumping out warm air is it safe to assume the control switch assembly in the dash board needs to be replaced?
Old Oct 26, 2011 | 05:54 PM
Daehawk's Avatar
Daehawk
That is a vacuum problem. It defaults to dash defrost. I'd check around the vacuum lines under the hood around the driver's side.
EDIT: I meant to say look for a leak in them.
Old Oct 31, 2011 | 11:59 AM
GARY247's Avatar
GARY247
Default heater controls
Thanks for your input. It saved by a bunch of money and was an easy fix. Cost me 65 cents for a rubber tube splice that fit over the line that had broken in two. For anyone with this problem is a line about the size of a pen refill that runs from a plastic vacumn manifold that is near the master brake cylinder.
Old Oct 31, 2011 | 01:19 PM
Daehawk's Avatar
Daehawk
Awesome! You're very welcome. Glad it was so cheap and you found it quickly. My heat was stuck like that all winter once. I could see where I was going but my feet and legs were froze when I got there
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
guitarman376
Sep 30, 2015 05:54 PM
Colin Ringle
Sep 15, 2015 09:27 PM
