changing clusters
Old Oct 28, 2011 | 11:35 AM
hdavew's Avatar
hdavew
Default changing clusters
will a 1999/2000 gt cluster fit my 1999 35th base, and will an auto cluster fit my standard car? thank you
Old Oct 28, 2011 | 02:50 PM
jthorn9's Avatar
jthorn9
The Godfather
Auto/standard doesn't matter, but the model does. The GT clusters will fit, but the speedo will no longer read right as your car is programmed for a 120 mph speedo, the GT has 150 mph. The other problem with be the RPMs as the GT has a higher RPM range and again it will be off. You'd have to get Ford to reprogram the ECU to sue the GT speedo.
Old Oct 29, 2011 | 09:43 AM
arabianobsession's Avatar
arabianobsession
Thanks for the info, that clears up some confusion!!!
Old Oct 29, 2011 | 10:41 AM
hdavew's Avatar
hdavew
Default where
our small dealer here, doesn't reprogram the ecu, where could I send it?
Old Oct 29, 2011 | 10:42 AM
hdavew's Avatar
hdavew
our small dealer here doesn't reprogram ecu's, where can I send it?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Sep 30, 2015 10:13 AM
lmurf60
Sep 24, 2015 10:07 PM
