keyless entry help
Old Dec 27, 2011 | 01:50 PM
green232's Avatar
green232
ok so they wont work with my factory installed unit.. so do you guys suggest i install the whole keyless entry and remote start system he gave me, since it came with those remotes, or should i just order another set of remotes, and hope for the best? i ask this because he gave me the full kit, just wasnt sure if it all would work seeing at it said it was for a 2001 mustang..
Old Dec 27, 2011 | 02:34 PM
belairbrian's Avatar
belairbrian
I think the first thing is to figure out what parts you actually have both currently in the vehicle and what parts wer egiven to you.
Ford parts does show parts listings for remote start on 2000 and 2001 Mustangs. The color and part number of the module determine if it is Remote Keyless Entry, Remote Start, or Both. They also list a remote start wiring harness. All parts are listed for Auto Trans.
Unless they moved it the remote module is located in the trunk behind the left trunk finish/trim panel. You need to see what is really there already. You may need to simply get FORD OEM remotes. You can get a pair for around $20. But only if the RKE module is already installed.
As for the pieces given to you, what part numbers are on the module? The remote part numbers appear to be after market remotes not Ford OEM can't say about the module without a part number.
Old Dec 27, 2011 | 04:04 PM
DRAGUL's Avatar
DRAGUL
Green232 sorry not to hijack your thread, but Belairbrian how familiar are you with the 2001 code alarm system. Are the fobs programed through the module once installed, or do you program like the owners manual says. Reason I ask is I have that code alarm system, but can not get the car to go into key fob program mode, with the 8 turns of the key. I have no owners manual for the alarm, and to old to get it from them. I have tried.
Old Dec 28, 2011 | 09:46 AM
green232's Avatar
green232
dubarado
Dec 23, 2015 01:16 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 8, 2015 11:50 AM
ccwebb
Aug 11, 2015 06:47 PM
