keyless entry help
Old Dec 23, 2011 | 01:15 PM
green232's Avatar
green232
Default keyless entry help
ok guys i need some help.. my 2000 was bought used.. it only came with one key, and no key fobs for remote doors trunk.. so my uncle had a set of ford factory remote start/keyless entry full system and all but it was for his 2001.. my question is, can i use just the remotes to lock and unlock my car without having to install the entire system.. i dont care for the remote start option.. ( would be nice but isnt at all required) i just want to be able to lock and unlock the car with a remote.. is this possible without installing a whole new kit?
Old Dec 23, 2011 | 07:38 PM
DRAGUL's Avatar
DRAGUL
The key fobs are to the best of my knowledge, not oem ford. No remote start option that I am aware of on a 2001 mustang. His key fobs are aftermarket.
Old Dec 23, 2011 | 08:10 PM
green232's Avatar
green232
its direct from ford.. i have it all here with me..
Old Dec 23, 2011 | 08:12 PM
green232's Avatar
green232
the kit is for multiple vehicles.. but it starts with 2001 vehicles.. i just want the remote entry.. so i was wondering since the 99-2004 remotes were all the same.. would these work..
Old Dec 23, 2011 | 09:20 PM
green232's Avatar
green232
Old Dec 24, 2011 | 04:01 PM
belairbrian's Avatar
belairbrian
what are the part and fcc numbers from the back of the remote?
Old Dec 26, 2011 | 01:32 PM
green232's Avatar
green232
FCC ID: goH-FOUR
Canada I409 K1425
Old Dec 26, 2011 | 08:34 PM
metalsludgerules's Avatar
metalsludgerules
Do you know the frequency its supposed to be on?
Old Dec 27, 2011 | 09:14 AM
green232's Avatar
green232
no i dont.. i dont know much about it at all honestly.
Old Dec 27, 2011 | 11:01 AM
belairbrian
That does not sound like a factory FCC number. Aquick search turned up this:
Code Alarm Remotes with FCC ID GOH-FOUR
Posted on November 14, 2011 by admin
A visitor to our call center wanted to replace a remote keyfob for her Code Alarm system. She could barely read the FCC ID number on the back because it was so used, but it turned out to be ”GOH-FOUR”.
As it happens, this FCC ID was used on two Code Alarm remote key fobs that have different electronic characteristics . . . so they are not compatible. One transmits a fixed code signal at 315 mHz; the other transmits a rolling code signal at 434 mHz. There is a further complication in that the rolling code remote is no longer made, though Remotes Unlimited sells compatible parts that may be substituted for it.
It is very difficult to distinguish the two parts visually, so our call center asked the woman to look at the control module of her alarm system to determine what model had been installed in her vehicle. Once she provided that information, we were able to sell her a replacement part that she will be able to program herself.
Situations such as this are not at all unusual, for either factory keyless entry or aftermarket alarm remote transmitters. So, when buying a replacement be sure you are confident that the vendor you buy from really knows the parts and technologies involved.
